LOL, and you believed them? Wow. Explains why you have verizon to begin with, sorry just joking could not help myself.
The normal droids can handle the speeds of lte. Heck most smartphone built in the last year can handled that speed. Metro pc launched a 4g phone, it handles the speed just fine. If you are being told that a phone could not handle the speed, they are lying to you. Almost any smart phone created today can easily handle 3x the speed that lte can give you.
I know you want proof that Verizon is lying.
Ok easy enough. Go to your phone. Turn off your 3g radio, turn on your wifi radio connect to a router. Now browse the web, able to keep up? Yes it can. I have maxed the radio out on the evo to 54mbps connection, and guess what, it works just fine. You can do it at home, just connect to a wifi router. Now when lte comes to your phone it is going to have a soft cap about 12mbps. With and average about 4-6mbps. So if your home connection is less then 12mbps, you will know your current phone could handle lte. About the same as wimax. Your wifi router can get most phones well above 40mbps, maxing at 54mbps. Do the test yourself and stop believing what you are told.
