3ricG
I have the Spigen NeoHybrid case, which makes most of my other cell phone chargers incompatible with my s4 (the rubber/plastic around the plug won't fit into the hole in the case). I'm looking to buy the same charger that came with the phone, since I know it fits. Unless I was looking at the wrong product on the Samsung web store, another charger will cost about $40. I've purchased other USB chargers like this in the past, and they were $10 or less. Is there another place to buy the exact same cable online? Has anyone found another cable that works well with the NeoHybrid?
