Where does agat recovery store nandroid?
Modman
Just want to know where it stores the nandroid because it says it backed up but didn't give me the path where the backup was going. just to verify backup files are there.
other recoveries let me choose backup location. this one didn't seem to.
Like the above post but check the phone storage it is usually there. I am not sure if you can get it to automatically be placed on an ext sdcard.
Found it on the external. Backups were there from my esteem which used cwm. So I moved the ones with earlier dates to another folder that I labelled. I had data from my old phone cause I didn't reformat my SD card.
I've always taken nandroids from all my devices but I've never had to use them. Except once cause I had to flash to stock to hook up a phone I disconnected to reconnect it to give it to my wife because I couldn't hook it back up with a custom ROM on it.
