1. Disconnect the phone from the PC
2. Open The Phone Book
3. Hit Menu (or the the 3 Dot thing)
4. Import/Export
5. Export to SD
6. Select PHONE or SIM account (dependant on where you store your numbers)
7. Wait for the .vcf file to be created (it should be created on the root of the SD Card, not in any folders).
8. Connect the phone to the PC as a Disk Drive
9. Copy the .vcf file you just created on to the desktop of your PC.
10. Unmount/Disconnect the phone from the PC
11. Log into the gmail account associated with the phone in your browser
12. Hit Contacts (in the top left hand side of the page)
13. More Actions
14. Import
15. Select the file you've just copied to your PC, let it upload
16. Click Contacts again, you should see the contacts from your phone listed.
17. Perform a Sync on your phone, it will download the contacts to your phone again so you'll end up with a few duplicates, but after your phone sorts itself out, then they'll link themselves.
