Help where is "kies"?
maltje
I instaled kies on my pc and I would like to install it on my samsung because there is an update ,but I can't find kies in the store?????
What can I do?
Kies is samsung's software for installing updates. You don't need it on your phone, follow the instructions on samsungs support site for your country to launch kies and connect your phone.
When you connect your phone to the USB cable connected to your PC, does your phone recognize the connection? While connection, pull down the notification bar on the phone and check to see what mode the phone is set to...
