Help Where is the display options?
darkjinni2
Member
I just upgraded to the Droid2Global from the original Droid. I am looking for the display options. Previously I was able to go to contacts, hit the menu button, then display option, so that I could chose to only display contacts that have phone numbers.
Where is this option on Droid 2?
I assume it's menu/display group/phone contacts, but all my contacts have phone numbers, so I'm not sure. BTW, if you are at the home screen and hit menu settings/applications/Double Tap Home and select "voice search" you can double tap the home button and say: "Call contact" and it will phone them. That's typically easier than looking through your contacts.
I have a D2G, but if I go into my contacts, hit the menu button, and hit display options, I have a checkbox for "Only contacts with phones - Only display contacts that have phone numbers". I'm running Fission 2.4.3, though, so that might be an AOSP thing that the D2's motoblur covers/removes.
You don't have the display groups options I mentioned, or it didn't work?
"Phone contacts" is all contacts from the phone contact list (as opposed to facebook or gmail), so it will include contact on the phone, but without phone numbers. Not what the OP was wanting.
