Where to find oem Samsung charger?
Gravytrain
I need one exactly like the one that comes with the s4 to fit my case and to have the same charging speed. All I've found was knockoffs on amazon so far... Where else can I get a real Samsung charger?
Use the 50% off coupon you get for registering your phone to get it from Samsung Direct or go to AndroidCentral.com's shop as they have the official charger there for $15
There are a lot of chargers out there that claim to be OEM, and even look 99.9% identical to OEM, but are not.
As said above, read reviews carefully.
Some re-pros are fine, and some are junk.
One thing you'll want to look at is how well they charge compared to a real OEM charger (charging current)
I bought a couple "claimed OEM" chargers from Newegg for $12.99.
They are not OEM but they are good copies, and the charging current is identical to the OEM charger, so that was good enough for me!
