Help where to get replacement parts?
Didn't see a back cover. Anyone know an email I can use to reach zte to inquire about replacement parts?
most parts are nearly impossible to come by except the battery on zte phones, you might be able to get them from zte directly though im not sure. call and ask
I used to use it for Google wallet until I borked the secure element. I wanna find out if replacing the NFC chip will fix that issue.
Support Hotline:
1-877-817-1759
Support e-mail:
devicesupport@zteusa.com
If you go the e-mail route you might have to e-mail them a few times before you get a response. If you're lucky, they will respond to your first message.
You could check eBay and other sites for someone who might have a bricked/broken/used/bad esn phone.
you have to modify the build.prop to set the device to one compatible with g wallet, then you download and install the xposed framework and the g wallet app and the g wallet module for the xposed framework. after setting it up you restore your build.prop and your set. there's more detailed tutorials if you Google it.
