Apps where to put system image for android 4.0.3
forsubhi
I download android 4.0.3 to my sdk and download system image and put it in images folder but sdk shows me that it doesn't installed what is the problem
I don't know what you've done.
To upgrade my SDK to Android 4.0.3 (API Level 15), all I did was go into the Android SDK Manager via Eclipse, put a checkmark next Android 4.0.3 (API 15) folder and then click Install.
I was asking about this dir
/android-sdk/system-images/android-15/armeabi-v7a/
if you download your image independently
my problem solved thanks
