Which app's using 3G & GPS???
Hi Guys...
I'd like to know if someone knows a widget or an app which 'll display in realtime who is using the 3g and the gps. ???
Cause i 've sometimes GPS and 3G icon ON whereas i'm not using anything....
I looked on my apps but i didn't find....
Thanks for your help...
What apps do you have that are location-enabled? Quite a few apps will periodically determine your location. Even without an app to tell you what's using your GPS receiver you can take a look at the running apps on your device.
Shopping apps and weather apps typically invoke your gps periodically. Some sports apps, too.
Shopsavvy is a big culprit. I used Ultimate Juice to limit it's connection to the internet only "when visible" and that's kept it under control. I use UJ to limit data connections of a lot of apps. Some I disable altogether.
