Which case for ME?
Smudgie
I would really like to have a case all set for next week when I get my Incredible. Ultimately I would like to get a skin for the Incredible that will fit into a leather pouch with belt clip which I can position horizontially. Getting a case that will be wide enough to also fit a skin on the incredible is not really a must for me. HOwever I really need a vertical slim leather pouch. I am unsure whether or not using a holster with a magnet will have any adverse effects.....any thoughts? Thanks
If you want leather I bet you will have to go with one of the universal PDA holsters Verizon sells.
I ordered the holster/shell off the Verizon site but it looks to be a hard rubber/plastic. I think it is going to be the best option for us holster wearers until some of the other manufacturers come out with more options.
