A.Nonymous
Extreme Android User
I just got my DInc2 today and I'm in the process of setting it up and transferring all my stuff over to it. I put the case on that I bought and quickly found out that it does not fit with the battery cover needed for wireless charging. The cover is just a tad too thick. Can anyone recommend a case that will fit with the cover needed for wireless charging?
