Which cases can I use with an extended battery?
I went through the same topics on this forum but they didn't relate to this phone specifically.
I see a bunch of you have gotten extended batteries.
Which cases are you using together with the extended batteries?
I'm looking to buy a case like this or similar:
Would I just leave the back cover off?
Is that "recommended" in the case of using an extended battery?
Or are there any specific extended battery cases?
Could anyone who is using a case post a link to the case online?
Thanks in advance!
there are no extended battery cases. you will never find one. there is a mod to only ine kind of case which is the hybrid plastic shell and silicon cover on top. you wouldneed to cut the stock plastic back cover and the plasric part of the case and the battery would only make the silicon cover stretch a bit out. was done on the esteem. i have a couple cases coming in the mail im going to try it and see what happens.
otherwise there is no other way
Those case manufacturers are missing out a big market... :mad:
Thanks for your reply!
I just use a pouch case. They're safer, keep the screen from getting fudged, and on top of that it's easier to access my phone, and I don't have to worry about constant radiation levels like I would if it were in my pocket.
