IHaveAnAndriod
3G (HSPA) or LTE?
I would think 3g
Agreed that 3g will use less battery. Just my thought but... I think the trade off of using LTE consistently and the battery loss/usage from using it is worth it and the battery loss is typically pretty minimal.
The biggest battery drain that I notice while on LTE is that when I'm in a poor reception area and the signal is weak and is constantly switching from say, LTE, HSPA+, HSPA or 3g. etc. That's when I notice the most battery drain.
Personally I prefer LTE as my preferred data connection and the better data connections/speeds for me are well worth it.
There are other areas of the device that can be tweaked and adjusted to save battery instead of sacrificing your Data connection speeds.
What are the such areas?
