hairy mole
My wife has a Nexus 7, and I don't know which type she has. I see that Android 5.xxx is in there. How do I find this info?
Thanks
Thanks
^^^That. If you have a lense on the top right on the back, its a 2013 model. Also, the back of the 2012 model is sort of dimpled where the 2013 model is smooth.Hi
The 2013 has a camera on the back, the 2012 does not.
Roger
The difference is HUGE.I have the 2012 one. I did not really see a reason togo to the 2013 one, the difference was not worth the update. I might be getting a new one soon though.
I've just got a 2013 one. The difference is amazing. No more waiting for a minute when I change the orientation of the screen, which is what happened on the 2012 after it got Lollipop. No more apps crashing.I have the 2012 one. I did not really see a reason togo to the 2013 one, the difference was not worth the update. I might be getting a new one soon though.
Also 1920×1200 screen resolution. Stereo speakers (surround actually) snapdragon s4 pro processor. And more I can't think of right now.I've just got a 2013 one. The difference is amazing. No more waiting for a minute when I change the orientation of the screen, which is what happened on the 2012 after it got Lollipop. No more apps crashing.
