Root Which Radio and where
Jaffa
Android Expert
OK how do i tell which version of the radio i am runing, and what is the latest, also, can update the radio without wiping my existing ROM? :confused:
Hi. To see which Radio you have go to Menu > Settings > About phone.
Check the version against the version here.
If your radio is old, download the new one. Put it on the root of your SD card (I.e. not in any folders)...
Power down your phone.
Hold the HOme button and power button down (assuming you have Amon Ra recovery and your rooted? )
Select flash from zip
Apply the radio update.
It is a good idea to perform a nandroid backup beforehand though
Question: I'm using Villain5.2, do I need to update my radio?
EDIT: Scratch that, checked the above thread ... and I'm already running the latest.
:D
