Root Which Rom for all usage
slash92
Hello, I have a X10i since its release and I do not want to change .... : D
my current version is the latest Update of Sony:
Android version 2.3.3
Base Band 02.01.71
The problem is these slowdowns on: open the browser (basic or dolphin), open my sms, contacts, emails ... Sometimes I wait 15 seconds or more for having such a function, .....!
I already used Memory Optimizer app but it does not change anything....
This is pretty bad and I would like to take a rom optimized and functional, I do not use 3d games ...
I wish I had the basics:
8m camera / video 720p
play video
gsm 2g 3g
bluetooth
wifi
gps
tethering (not working with all roms :( )...
My goal is to gain fluency / autonomy and compatible with my application (one hundred)
A simple and nice / customizable would be a plus :)
Thank you in advance for your advice;)
I use TEAM Rom
Most common problem I see with x10 users is that they never clean their phone or reinstall. Or they have 1000s of text messages they never cleanup.
Just like a PC, you should re-format and reinstall everything once a year if you are a heavy user.
Backup what you need onto a computer. Then wipe the SD Card clean and install a ROM from scratch.
Do not install any additional apps unless needed....especially any sort of memory optimizing programs or antivirus or games....or timescape.
