Root While flashing optimus m LGNPST Error then stuck at metropcs logo
andnoob
So The problem started wwith Rom Manager, touched that 'back up stock ROM' button then lg logo in my face. So i followed a guide and got it working and but i was zerod out. got it fix but couldn't make call etc. then decided to reflash. then i got stuck on the metropcs screen after an error about 'SYSTEM Bad Block' accured computer now has trouble keeping the phone connected
that sounds bad....
Your only hope is to do the unbrick from lg screen method. Maybe the file used for this got corrupted, redownload it to make sure. If you can manage to get it working back to the point of being zeroed out it is ok, if you keep getting this bad block error... i dunno bout that one man, it doesn't sound good.
my computer keep saying 'USB device unrecognized' I have the driver and everything installed. isnt there a way to sweep the phone clean? then start over
yeah I cant make calls but The service is up and running. if I try to make a call the service says "N,J,F 0 1 your call cannot be completed as dialed" but im 100% sure i know my own home number.(i tried others too no luck) any suggestions?
I already recover MEID,MDN,ESN, from whiterabbit and i got a MIN from a frien with the same exact phone in the same area 201-
still no luck.
This phone hasnt been with me for 3 months yet
Thanks alot Andacova appreciate it.
I ended up calling metropcs for my MIN number everything is working again after I put it in ##626* programming thingy
I think that means the partition was messed up but the data wasn't overwritten.
There are 2 way to 0 from what I can tell. And one of the always wipes out everything. You got lucky, lol.
