Root White screen problem
saivignesh
Android Expert
urgent help needed
getting a full white screen on my a75
tried flashing with sp flash tools but even after flashing getting the white screen
i heard somebody had similar problem in past
any solution????
hi,i have had this problem earlier, try flashing with format on sptool.
i used gionee rom and it was restore.
format option not working on sp flash tools,,,it keeps searching for phone
which format option???
how to do that
Buddy u r the expert in format+download and now you only telling us that its not working remember the option doesnt work untill u brick your phone.
yaa the phone is not bricked
we got to find the usb download button for our phone to format+download
back+menu is usb download button for spice mi 350n
just flash the stock rom it will be fine i had this issue earlier.. tried many things with flash tool but nothing worked then i flashed the stock rom and it was fine then. :)
guys I fixed the white screen issue myself
its just the issue of loose lcd flux cable
connector
thanks to abhishek kumar for providing me
the address of clone mmx server
those service centre bastard asked rs.500 for
this minor issue
but 1 small size philips screw driver did the
trick :-)
yaa I tried flashing it numerous time but no luck,,,I still however fixed the problem
I have this issue everytime I flash a new rom it works fine without screen lock but with screen lock it gives me a white screen any solution plz....
