Still doesn't work.The odd thing is the adapter worked fine on my [old] Galaxy Tab 10.1 running on ICS but for some reason it doesn't work on my Galaxy Note 10.1. running on JB 4.1.2
What version of Android are you both using?
Thanks
In the description of the white one it says "Data sync and charging support"
I can get the black adapter to work if I reboot the Note 10.1 whilst the adapter is connected to the Tablet, but this only happens just the once. If I want to use another USA stick I have to reboot again.
I have a third party one that works on mine but only on a usb stick with less than 8gb capacity. What's the max capacity the Samsung one will take?
Data sync means you can connect it to a PC to copy files from to to Note. That is it.
Could you expand on that please?
thanks
