Who here has bike mounts for their phone?
Hi all,
Anybody here from NYC who use their phone as a cycle-computer/GPS navigator?
What kinda mounts are you using? Are there ones with like a quick detach option?
I just got a ram mount but i'm not sure if its quick detach or not.
Also what kinda apps are you running?
thanks for your help.
Hi all,
Not sure if you are talking bicycles or motorcycles but should be the same answer. I use a ram mount on my motorcycle and yes it is quick release. Just loosen the knob on the ram mount and it's off. I also have a cheap adjustable holder for my phone that I just velcroed onto my bike on the front cover. Works great.
Hope this helps. (Sorry, I'm not from NY)
