Why do I not have the Same Finder and Quick Connect widgets on my pull down notification center?
I see both the S Finder and Quick Connect widgets on other people's Galaxy S5.
Depends on which carrier you have, and how they have configured that Notification Bar
Look up on the top right corner of the bar when you have it pulled down.
See the 4 little blocks arranged in a square?
click on that and you can change what is presented to you on the Notification Bar. It is a Drag 'n Drop method of doing it. Pull off what you don't want, and Drag up what you do want.
Look at the screenshots, the 1st is with just the bar pulled down.
The 2nd is after you click on the 4 blocks to open up the Options list.
When it is open, you can touch one of them and toggle that feature on/off.
If you click on the Pencil, you can edit what you want on the bar.
ur lucky.. cuz i dont want sfind on mine.. or quick connect.. im with sprint.. so... there is no way to disable them.
