why does my pone keep restarting
  • Start date Start date
A
Android Question
Guest
why does my phone keep resarting like i turns on says andriod then turns off and keeps doing the same thing
Hi
That's called a bootloop. It's probably caused by a corrupted bit of memory which the phone needs to start up. Suggest you register on the forums and post your question in the section specific to your phone where someone may be able to help. Include some more information.
Make and model of phone
Android version
What shows on the screen exactly before it restarts
Did anything odd happen before this started
Good luck
Roger
