why does s4 keep making bell ringing noise
Hi!
here are two solutions (there are more actually but these two are the more elegant ones).
1. check your notification bar when you hear the ring, and see which app is causing it. open the app, go to settings and disable the sounds.
2. go to the general phone settings and chose sound. Disable system or app sounds.
Hope this will help :)
