Help why is that?
hi guys , i just bought a galaxy ace and as you know it's has a small internal phone memory, any way i was wondering , why when iam installing apps on my sd card (on sd card) the phone memory is getting lower, how can this possible???
thanks in advance.
you know the more information you give us, the better the answer is going to be, and more information doesn't mean writing sd card twice for whatever reason ;)
there is a tutorial in this forum how to install all/most?? (didn't read it) apps on the sd card.
but there's still the dalvik cache for example, and i think some other cache that will be stored on your internal memory unless you have darktremor a2sd (to get that you need a special rom or idk run scripts till you're dead).
why do you care? i never had problems with internal memory, big apps can usually be moved to sd card (like angry birds), the rest doesn't use much space, i always had 80mb free even with 40+ apps even before i got darktremor a2sd.
also remove all apps you don't need because it may speed up your phone significantly, you are most likely to run out of RAM before you run out of internal storage (except if you only install well coded apps, chances are high you wont).
thanks man for your replay, but this is the problem all my apps on sd card ,when i unistall it from the sd card ,the phone memory increase, and when i move the apps to the sd card nothing happen to the phone memory it still small, and i as told you i just bought so idon't understand what dalvik mean or darktremor, and where does the data go ? for example angry birds it's 16 mb but i saw it only 2mb on the sd card so where is the other 14mb goes? and if it was on the phone memory how can i move it to sd card?. yeah and one more thing my phone memory only 4mb left and i only have 5 apps on it all smaller than 3mb.
i'm moving the apps by app2sd program, i guess i have more than 50 apps, and today i tried to install angry birds and unistall it, after unistallation, it gave me more than 10mb free on phone memory , how can that and i'm installed it on sd card?
about the topic are you sure that it's not rooting?
