ROMs Why system.img file is not flashing via fastboot
Sir, I'm flashing system.img file to my micromax a27 via this command "fastboot flash system system.img" but it's showing error. But I am able to flash recovery or boot via fastboot. Only system.img is not flashing to my phone. Why? Pls help me immediately..
If you have the recovery IMG and it flash try to get into recovery and you can flash the system zip file through the recovery.
It would also help us to help you to know what the error message was. (If it's a hardware error - and it can be - there's no way you can fix it yourself.)
Or as that being said you maybe flashing the wrong system IMG . your IMG may be international and you need just a USA . so check IMG also and tell us what your error msg is.
