Why won't this Identifier Token work
  • Start date Start date
A
Android Question
Guest
I have an HTC One S Model # PJ40110 on Telus. I bought it with no OS and TWRP 2.1.6. I have updeated to 2.6.3.0 but i can't unlock the bootloader. Is there a problem with the token identifier below?
Thanks
<<<< Identifier Token Start >>>>
9E2EB3DD85DDDE4D40E1F8244F193587
9319A4134911441842F37750A99F4384
6B834CA9D33FAE3D4A5EDF85D29B8957
2B2563110998C976DFB6F2923A7666E5
6348AF26CDEC013A33EB2ADA1FB529DB
D38EA7091D78BC0184624AB39F8D6D27
73F65DEF981BBF1DF4A234BF8EEC5F64
B25BF21F0A934D1ABF3F5215A5D73413
6C985EA6C3E7A548F5DB2552A91F89C7
8D4D8F2F2DA5059289E0A2F29DBDC02C
754657D7D524F16D0032530D698723C5
0FA1F14991D09D56518764277266348A
9D44EAFF70E433A6A283792023F1C686
AB78B4545FEBCD438AF7FAB2BF2D0946
55418DC9D32F70A58405E053C5B6AB43
434CA39974711C05ACE104CA85A4D450
<<<<< Identifier Token End >>>>>
I can't answer that, but if you have TWRP on it it must have been unlocked. In fact in order to update TWRP surely the bootloader must still be unlocked (you are flashing the recovery partition when you do that).
Why not use "adb sideload" when running TWRP to copy a ROM onto the device and see whether you can flash that? Only thing is that I don't know the One S well enough to know whether it's one of these devices you need to separately flash boot on if you are S-On (you can tell whether you are S-On or S-Off from the top of the hboot screen).
