jaysith414
For anyone having problems with Wifi not obtaining ip address or not connecting since updating to froyo 2.2 or possibly even before 2.2 TRY THIS!!!!
It will force android to create a new file which solves all the wifi problems. I guess during updating to 2.2 the file gets corrupted somehow and causes a bug
I tried everything intill this it worked right away didnt even need to reset the phone
- First, You need to have a rooted phone
- Make sure to turn off wifi in the settings
- Then open Root explorer (or any app that can access root folders) and locate the file dhcp_list
- And all you have to do is delete the file /data/misc/dhcp/dhcp_list.
- After deleting the file turn wifi back on and make sure to delete(forget) any existing connections you were trying to connect to before.
