Help Wi-Fi IP STATIC cannot browse, why
Hi all, i have a problem regarding my internet connection using fix ip(static) at my office...can connected but cant browse. In public wifi (dynamic ip) it can be use/connect/browse. Please help me if any setting have. Already tick at IP STATIC in my wifi setting on my Galaxy Ace.
THIS IS DATA ON DLINK.
Model Name: DSL-2640B
Time and Date: Tue Nov 1 08:16:10 2011
Firmware Version: GE_1.07
INTERNET INFO
Internet Connection:
Internet Connection Status: Up
Mode: G.DMT
SNR Margin (dB)down/Up 21.6/19.0
Attenuation (dB)down/Up 60.0/31.5
Default Gateway: 219.93.218.176
Preferred DNS Server: 202.188.0.133
Alternate DNS Server: 202.188.1.5
Connection Up Time: 00 day,00 hour,29 min,49 sec
Downstream Line Rate (Kbps): 1536
Upstream Line Rate (Kbps): 512
Enabled WAN Connections:
VPI/VCI Service Name Protocol IGMP QoS IP Address
0/35 pppoe_0_0_35 PPPoE Disabled Disabled 175.145.149.213
WIRELESS INFO
Select SSID :
MAC Address: 5C:d9:98:B8:BE:C3
Status: Enabled
Network Name (SSID): ***********
Visibility: Visible
Security Mode: WEP
LOCAL NETWORK INFO
MAC Address: 5c:d9:98:b8:be:c2
IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
DHCP Server: Enabled
THIS IS DATA ON WIRELESS CONNECTION.
Physical Address: 00-1F-E2-B5-A8-C0
IP Address: 192.168.1.2
Default Gateway: 192.168.1.1
DHCP Server: 192.168.1.1
Lease Obtained: 01/11/2011 7:46:49:A
Lease Expires: 02/11/2011 7:46:49:A
DNS Server: 192.168.1.1
WINS Server:
GALAXY ACE > WIFI SETTING > ADVANCED > IP SETTING > USE IP STATIC > IP ADDRESS.........? > GATEWAY..........? > NETMASK.......? > DNS1......? > DNS2..........?
So anybody can help me which one data/figure need to put in galaxy ace WIFI SETTING and i will try to check one by one in my phone....Thanks
Sorry for late reply, when you make a forum post on the left side you will see prefix and a dropdown menu make sure you choose the right prefix for example suppoert or general
