Wi-fi problem
pep011
Hy, i have a Galaxy Next Plus(it's a tim-italian version of pop plus) and everything was fine since i flashed Jelly Blast rom.
The problem is that i can't connect to wifi...no no. I CAN connect(it says connected) BUT there is no internet acces.
I mention that when i bought the phone wifi works but after roms flashing it does not.
What i should do to fix it?
P.S.:i tried reset, data wipe restart, battery pull, dial *#*#526 or something... etc and i still can not acces internet with wifi connection (i can use hsdpa)
Sounds like a problem with the ROM you installed. You probably need to contact the developer to find out if there's a fix or I guess you could put the original ROM back.
I think so. But it seems like noone with this rom is having this problem. And is not the hardware because if i flash stock rom everything works.. I really like this rom and except this problem i think is best for my phone.. so hope i can find a way fix it
