Wi Fi
is it activated? (Use the power widget available with android) It is really usefull.
Do you see the icon with the wifi next to the battery?
Are you sure you got signal?
Did you connect and enter password of the wifi?
Yes to all the above. It shows excellent connection. It use to not connect and wouldn't even show that I was connected but it does now just without any internet connection. I've got to get some sleep but thanks for the quick reply. I will check back tomorrow.
