Widget Control
Hello
I have a Samsung Tab 2 10.1 tablet and am just wondering if there is a way to control the widgets that are installed on the tablet. I have for example installed Folder organizer and Icon changer both of which i use but when i go to the widgets screen there are 17 widget icons for Icon changer and a whole slew for Folder organizer. It would be nice if these could be put onto their own page or folder somhow. I have looked and searched hi and lo but there doesn't seem to be anything out there to do this.
Anybody ???
That is controlled by those two developers. The only thing you can do is either remove the app or contact the app author and suggest a change.
... Thom
