Hi,
I have a rooted San Francisco/Blade, updated to 2.2 but I've noticed a problem with widgets of late.
When I reboot my phone my active widgets vanish! In their place on screen is a white square with "Problem loading Widget" written in it.
When I go into the widget list it will be missing although it shows up in my applications drawer.
I've done quite a bit of fiddling with the phone and have a few apps that move things to the SD card (Apps2SD and Move2SD Enabler) and imagine it's something to do with these.
I uninstalled my vanished clock widget and then reinstalled it but it installs directly to the card. Even if I use Apps2SD to "Move to phone" it seems to make no difference!
What I can't figure out is how to download my apps directly to the phone and then move them to the SD card only if I say so.
I had a few other apps I downloaded whilst trying to optimize the internal memory but I'm starting to forget what they all do/have done now!
Is there some magic button I can press which will keep my downloaded widgets in the phone memory rather than putting them onto the card?
Thanks for reading
Mark
Thanks for reading
Mark
