Widget locker and simi folder problem
prooz
This might be the wrong section, we'll see.
On my device (galaxy ace) I loved the combination of simi folder and widget locker. I used to put a shortcut to a folder in a custom slider and this have quick access to more apps more quickly without taking up too much space on the screen.
A few days ago I upgraded and bought the galaxy note 2. Now when I put a simi widget/shortcut on the widget locker lockscreen I must first unlock the device with the pattern before the apps pop up. Is this because of the new device or is there some option I must check/uncheck? This is also the case with AlarmDroid. I have to unlock the screen to shut off an alarm.
If anyone happens to have any suggestions what do ever I would really appreciate it.
It's been a while since I've used WidgetLocker, but it sounds like that's where the problem lies. There's likely a setting in there that needs toggling. If you don't get an answer here soon, try emailing the Dev
