BlueGecko
Discovered last night that the widget panel on my Samsung Galaxy S10.5 tablet (model SM-T800) is half empty. I'm running Android 5.0.2. Never a carrier on this tablet. I've only used WiFi. I'm using Google Now Launcher. Not rooted. This is a new issue.
So when I long press on any home screen, and then choose "widgets", and the panel slides open, the widget panel slides open to full length - but only half or so of the widgets are there, scattered through the panel.
When I finally did a factory reset last night, the widget panel was full again - but it wasn't running the Google apps it's been using without issue for the last years. When I updated, the widget panel is messed up again.
Any ideas?
Any ideas?
