Widget question
Is it possible for Tasker to remove/replace widgets by other apps. I want to switch out my music widgets (Google Play Music and Moodagent) depending on which app was used last.
Would it be possible to make a shell script or edit settings in android to change the widget? How are app widgets stored, are they just a SQL entry or are they a file somewhere in the internal memory?
My phone is rooted, Motorola Triumph running 2.2.2 with Tasker 1.6.
