MattG92
Member
Hi All,
I just tried out Nova launcher and was disappointed to find out that I cannot use some of the widgets that I like.
I believe that this is because they are part of the touch-wiz launcher rather than being a separate widget like all the rest.
The widgets I am after are the full month calendar view, the task view and the day agenda widget.
Can anyone either help me find a way to use these with the Nova launcher or suggest other apps/widgets that do exactly the same thing?
Thanks
Thanks
