HTC Sense has a widget to enable and disable your data connection. I don't want to use Sense though, and since disabling it, I don't have that button anymore. Anyone know of a widget I can use?
On my droid the only app I could find that actually worked at turning off the data is called GTWidget data. None of the other commonly mentioned apps work on the droid. Not sure if that will be the case for you though.
