Widgetlocker stops music player
ferdossi
Hi,
I have widgetlocker 2.2 installed.
It works fine expects for some music/radio players. If I set screen to turn off after 30s, then when screen turns off, music stops, as if the player could not keep one playing with a locked screen.
I uninstalled WL, the screen turns off and gets locked with the native android lockscreen but this time, music does not stop.
Is there a setting on WL for that?
Thx.
One more precision, this problem occurs only on players that are not multitask, I mean they have always to be on forground the work.
And problem with WidgetLocker is that it overtakes the process from the monotask player and so the player stops, wheras it does't with the classic lock screen.
I don't know if there is anything you can do for it to work. Maybe disable the notification icon, but I doubt that would do anything. Although, personally, I would be looking for alternatives to those apps that have to be in the foreground to work.
