michalik.piotr
Hello....been trying for a few days now to get a screen lock widget to work unsucessfully. Any suggestions?
Been tryin to get the switcher 1*1 to work set up as "auto lock" to toggle the pattern lock off and on. Just does not work. I have the widget icon on the desktop but when i tap it the bar under it does not light up and when i turn the phone off and on, i am not prompted to use the pattern.
yes, i am rooted.
i am also using "screen unlock" to avoid using the slider.
i rebooted, i set the setting to "toggle" in apn, widgetsoid is added to device administrators.
can't get the toggle to work in Mini Info app either.
Help? I must just not be selecting or switching something on? or off?
yes, i am rooted.
