I have WiFi set to turn off when the screen turns off (default action).
But looking at the native battery app, it shows the screen turning off now and then, but the WiFi is on almost all the time. The blue bar has only a couple of small breaks for WiFi during the past 6 hours.
Now what's weird is that I think WiFi IS off. Because when the screen is off, I can't ping the phone from my PC. Also after turning the screen on, I see the little 3G icon, and it disappears, and then appears the WiFi icon.
So how can you explain the WiFi bar being almost always on in the battery usage app?
