Help Wifi and mobile data problem + 2 more
Rogach
Hi everyone. I just bought the galaxy s3 5 days ago and i'm very pleased, however, i have 3 questions/problems.
1. So i have a Wifi network at home and i can connect and everything works fine. But after a few hours of being connected, i can't go to the internet. The signal is still there, even at full strenght but i can't go to the internet and i can't refresh any app that requires an internet connection. The thing is i also have my laptop on the same network and it's working fine. The solution i found is to restart the phone and then it works again, but it's annoying that i have to restart every 2-3 hours. I also tried this on different wifi networks and i get the same problem. So the issue is defenitly on the phone and not the router.
Very similar thing happenes to the mobile data network. It works fine then all of the sudden i can't connect. After the restart it works fine.
2. So i have a folder where on my music is on the sd card. But i also have a folder with some game data that has it's own mp3 files. And when i open the music player it shows all of my mp3 files and if i want to listen only to the real music i have to create a playlist. So is there a way to create a playlist that includes all the files from a folder or do i have to click evry single file in the playlist creation menu on the player? I have like 1000 normal songs and 1000 game mp3 so this method would take loads of time.
3. The back cover over the volume rocker makes this noise when i press on it. The entire cover feels nice and solid, but over the volume rocker it gives in a bit and make a noise. Is this normal? Or is my cover broken?
Tnx.
Regards your first issue, It appears that there are a few of us having the same issue. For me the 'disconnect' can happen after minutes or hours.
I noticed it after I updated the firmware, but cannot guarantee that I just didn't notice it before. I have phoned Samsung who have told me that its a known issue with the firmware and that somebody from the 'specialist' team will call me back. Not heard anything yet though.
If I hear nothing by the weekend then its going back to the shop (Tesco) for a replacement!
