Help Wifi Authentication Problem
  • Start date Start date
  • Tags Tags
    wifi
A
Android Question
Guest
Every time I leave my house and come back my phone will disconnect from the wifi and say authentication problem when I try to reconnect. The only solution that I found is to restart my router but when I do that effects my tv connection as well and I have to reset my tv as well so I cannot keep doing that. I was wondering if there is anyway I can stop my phone from do this or a better solution for when it does?
Sounds like your in need of a new router or reset the router, are you using the same username / password as for the PC?
