Help Wifi auto-connect Support Question
jlb0305
I have two wifi locations set up on my inc as preferred. It used to automatically connect to which ever of those two it saw as soon as I turned on WiFI with my widget. Now i have to physically go into "settings -> wireless and networks" and then it sees the network and connects. Is there a setting somewhere I changed or something to get it to auto-connect again?
hmm....there is an advanced menu under wireless settings...just hit MENU key when in wireless settings and you will see it although I don't now if what you are looking will be in there
Any Solution to this? It's really annoying.
Thanks
Which includes a checkbox for improved WiFi performance. Just what I need on the 1st floor!, thanks.
Have a new tip on this... 'unlock with WiFi' will preferentially lock onto your home WiFi and only look elsewhere if it can't find it. Yes, it unlocks your phone too, but you are at home, so not a huge problem there!
