Wifi calling
billtowne
I have it turned off just because of the dang persistent notification on my Tmobile branded phone. Anyone know how how to make it disappear?
Have you tried forgetting your WiFi network and adding back to see? I have a different carrier and no issues with mine staying off!
Change your preference to cellular network. The wifi calling will be gone unless you have no signal and are near a wifi connection.
I have, but I would prefer to use wifi calling when I can. I just don't want that icon always there.
As for forgetting the wifi and then adding it back, that didn't work. Bummer....drives me nuts!
What you have to do to accomplish that notification off your phone:
Tap and hold on that notification, then a gear circle will appear inside it, tap on it..that will take you to settings of that app..then you will be presented to the option of turning off the notifications in a check mark..you have to uncheck it..by default is already checked..
Let me know.
When I click on the notification and I go to settings, I get these, but there is no option for turning off the notifications.
Actually let me rechapter:
Press and hold the notification..but you don't tap on the gear..actually it's on the icon next to it
