wifi connect problem
sylvia52
Hi
yesterday my home wifi on my samsung galaxy 2 connected no problem.
Today it connects, remembers then immediately disables. it keeps looping this way. Any solutions?
Thanks so much.
That can be pretty annoying.
And you certainly want to be able to use your Wi-Fi for internet access whenever possible.
Try going into your Wi-Fi settings and have your phone forget your home Wi-Fi that you are trying to connect to. Restart your phone and then after your phone scans for your network and finds it select it and enter the password, and try connecting ( make sure you enter your password slowly and make sure its 100% correct).
This should help.
It sounds like it is just a connection issue. If for some reason you still have issues then try some of these suggestions for fixing a Wi-Fi connection on an android device.
Good luck sylvia52, let us know if you run into any issues.
~james~
