Help WIFI connection problem solved
I didn't see this solution if you are having WIFI connection problems. Menue/settings/wireless&networks/WIFI. Mine just kept showing optaining IP address but never connected. By accident I found out that if you press long enough a window will pop up with the WIFI settings for that connection, I had to put in a password. Bada Bing..connected. Whish I knew that earlier.
