Wifi Connection Problem
kiat5427
As we know, android phone can easily connect to the nearer wifi router to access internet. But my HTC Desire X when it connected to my work place router, i can't access to internet even it stay connected to the router while my pc was able for internet accessing.
Do anybody can help me to solve this problem? Is't the setting of the router or my phone problems? But the other public places wifi i can access it by using my phone...:confused::confused:
I would also ask your boss if your Wifi at work is able to be connected to by outside sources.
I know my old job would let you connect and everything but not give the device access to the internet.
My laptop can connect and access to internet, but my phone can only connect to the router and no internet access... The articles were not very helpful T_T
Install the app called wifi fixer with your cellular data. This app will solve all the issues of wifi.
Erm... i dun think my phone wifi got problems, because it can be easily used in public wifi even others places which protected by WPA or WEP security...
