Help Wifi connection
  • Thread starter Thread starter j2w
  • Start date Start date
J
j2w
Guest
Azpen tablet with 4.4 KitKat system
My tablet connects to the internet through a USB PC adapter. The tablet and PC both show wifi connections are made, but none of the tablet apps will connect to the internet.
Try using Virtual Router or similar software on your PC to create a hot spot. The way you have it connected (ad-hoc) is not supported in Android
