D
Deleted User
Guest
Hello. I've had my (first) S8 since 4/19 and since the first moments it was activated, wifi would disconnect and reconnect immediately. It would do this several times in a row sometimes, then be fine for hours as far as I could tell, then do it randomly from time to time.
It is not the network, because I've used it on multiple networks I connect to regularly and no other devices had this problem. So I called Verizon today and they said it was not a known issue and suggested I swap out the phone at a store while it's still returnable.
So I did just that...and it's still happening with the second phone.
I've had a S6 and S7 before this and have nothing set up differently and no new programs installed since running the S7 with Android 7.0.
Is anyone else experiencing this issue?
